Fix one thing break the other
By diamondjfarm
Thanks.
By Alien10
A while back I was looking at an auction UTV plow and the mounting of it. Looked like it had an "H" bar with two pins that hooked into brackets on the front frame of the UTV. I have a bunch of 1/4" x2" angle iron, and some 2"x1/2" flat stock in the barn. I was thinking of welding up a bolt on implement mount that would provide 2 holes about 14" apart, that pins could be used to hook up an "H" frame for a plow or even a straight bar across with pins to hold it in place. The angle iron "A" would utilize the existing bumper mounting bolts front and bottom, and have the two channels "B" with holes for individual pins or one large bar across. Those channels would be welded to the ends of the angle iron.
Anyone ever try this for a front mount? It would be close to this one that is for sale on the net. It is supposed to fit a KFI plow mount.
By Joe Breaux
just an update on my MSU 500 . For all the misery it caused me the first 2 yrs, and the combination of some quality YAMAHA parts, it has now become a reliable ,useful UTV without the constant fear of having to push or tow it back from trails. I have not had a single issue pop up in a very long time.. FINALLY!....and as a side note, I just bought a C FORCE 600 ATV to replace an old and well used Honda that finally after 18 yrs gave up a rod bearing. So far the new one has really impressed me .. I like the new Power Steering and this CVT Auto Trans is new to me on an ATV .. I m used to constant shifting on my Hondas . It also has something I have never seen. Its EBS engine brake system, as soon as you let go of throttle, it engine brakes you to a stop rather quickly.. its great idea for the grandkids safety . Takes a little getting used to tho.. All in all, I like it. We shall see how durable it is after break-in.. I do "RIDE" them! .....and they honor their warrenty! and the dealer is 15 minutes away..
By Reuben
My 2015 450i UCV dies when I take my foot off the accelerator when traveling at a slow speed. Can I adjust something to make this issue stop?
