Kawasaki KAF300-C
By lmarkie
Any thoughts?
By sxr951
parts for massimo, hisun,etc in florida? where can i get parts for the massimo 700.. like bolts and console i didnt see any bolts on amazon to go with cylinders and any thing when rebuilding a 700 engine
By Ronald
Check engine light comes on after engine runs continuously for 5 minutes or so. I can shut down the engine and restart and check engine light goes out, then comes back on after running 5 minutes or so? What ya think?
By Mater Help
I have a 2019 Bennche Warrior that I mostly use around my property for odd jobs. I also cruise the neighborhood and make short runs to the local pub and neighbors houses. The exhaust system is super loud. I was hoping to find something that will fit and work that is quieter. I have included a photo of the system that is on the unit now. Any ideas or recommendations?
Second question: Recently, it has become hard to shift from park to any gear if the engine is running. The shifter moves fine if the engine is off. It is almost as if the clutch (no pedal) is not disengaging completely. I have not tried to do anything to correct the condition yet but as it gets increasingly more difficult, I need to do something. Looking for a place to start. Nothing in the service manual that I can find.
Any help will be greatly appreciated,
By Robert Merritt
I have an older Bristers Trailwagon model TW11 with a Honda engine. I am trying to find a replacement muffler for it. It is an unusual muffler tapped in the center instead of the end with the heat shield welded on to it. Does anyone know where I can find a new one?
