  • 4 years later...
silverbullet
It is 70% and air pocket.Jack up back  and then slowly ad coolant.If it starts to back up put the cap back on and let it cool.Some Joyner have a tee shape on hose buy the end of block if so take the little line off with the motor cool not hot.Then try to fill it up.If not just get the buggy on a 45 deg. hill and start it up and keep filling.In the end all sides of the radiator.Should be hot.You did check the thermostat first.
    • By hdtran
      Hy (pronounce he), just bought a Hisun Sector E1.
      I'll be using it to haul logs and stuff in the Sangre de Cristo mountains.
    • By Rufus Fruge
      Just wanted to check in and say hi to fellow members. I bought a 2023 T-Boss 550 last month just in time for hunting season. So far all is well. I went over it to check things out and learned a lot in the process.LOL! I certainly would recommend that all new purchasers should make it a point to do this because I can promise you that you won’t regret it.
    • By tim hughes
      hello everyone
    • By Haskellz
      Hello guys!! I just joined the forum so there are so many things I don't know yet, I hope to have the help of the boards, and I really want to get to know you all on the forum.
