Front Wiring
By Bryan83c
Need input on compatible clutch sets I can upgrade joyner 1100cc 2018 sand viper with. Something autozone might carry and what cars are these chery motors most compatibility with
By nods
Less than 40 miles can barely start. Dealer is working with Hisun on a number of other issues on this UTV. Can not get clear info on the meaning of these E codes this is getting. Anybody have some clear info for me?
By Hector
Hello all,
I got a 2009 T2 and found the wiring on the fuse box that holds the fuel pump and ecu power had a short and was not wired correctly. I wanted to see if anyone could provide a picture of the back of theirs so i can see how it is wired
thank you
By Pablo
Hi. Ive been searching for a wiring diagram, hopefully with photos, part #s so I can try to repair damage from rats eating wiring over the winter on the M550 cub cadet UTV. (sigh). haven't had any luck. i have a plug with dangling wires from under seat, next to battery compartment and hope to take to dealers to see if he can order replacement and hopefully it comes with long enough wires that i can splice back into remaining wires. not going to be easy. I'm not sure if there is any more damage, but would have to disassemble to get to bare chassis. sigh. not sure I can do all that, but just trying to find a diagram with photos. no luck. any ideas. thank you.
By IslandHopper
Can anyone tell me if their MSU 500 or 700 fuel pump and injector cycle when you turn the key on? This will help me rule out the Crank Position Sensor as a problem.
I just bought this non-running and the service manual is not much help.
