THURSDAY AUGUST 28TH
11:00am to 10:00pm Top 50 Rally Park camper check-in
2:00 Legend Off-Road Air Suspension Tour and Media party
5-10pm participant check-in and on site registration
FRIDAY AUGUST 29TH
8am-10am breakfast is available at Top 50 Rally Park
8am-9am participant check-in and on site registration
8am-9am GPS Kiosk open (BRING YOUR CABLES!)
9am Black Hills UTV Welcome Ceremony
10am-7pm Top 50 Rally [...]
View the full article
    • By Jim Kessell
      2005 American Landmaster
      EH65 Subaru Robins
    • By Jerrys500
      Thanks Jerr
    • By JSwearer
      Does anyone have any suggestions for aftermarket shocks.  I have a T-Boss 550 and took it riding in some rough trails and the stock suspension was uncomfortably rough.
    • By Kingfish
    • By 2scoops
      I am in need of an IAC for my throttle body. I contacted JMC and they said I had to buy the whole throttle body for $209. I left a message at Joyner USA...they haven't called back. I found a Chinese company which have them for $17, but shipping is $32. With that I still have to hope it is the correct one which arrives.
      Does anyone happen to have one laying around they would sell?
      I understand a workaround would be to eliminate it and use the idle screw. I believe that would cause problems with cold start ups??? Elevation changes???
