I would appreciate it if somebody would point out to me the connection to connect a hose from the fuel regulator to the intake manifold. The fuel regulator nipple is obvious not sure where the connection to the intake is? Thank! Steve
    • By Ed Michael
      Subaru SxS.mp4
    • By Blair
    • By weasel
    • By Jim Kessell
      2005 American Landmaster
      EH65 Subaru Robins
    • By Buddee
      2010 Hisun 500 - Carbed'.  She sat for about 3 weeks since last use.  Couldn't get it started.... has spark but plug was not wet.  Bought new plug, cleaned the carb, confirmed fuel pump (pulse type) is working.  Still nothing.  Put gas in the plug hole.... started right up and idled as normal and drove perfect.  Used it for the rest of the day without issue.  Tried to start again next morning.... same problem.  Poured gas in plug hole again.... started up and best kind again.
