Hi fellas anyone knoe where a guy is suposed to wire in the off road light bar? My 2012 came with the top rack and light bar and i cannot find the pigtail for the light bar. It has a switch in the dash just for the lightbar but cant find the wires. Any help would be great thanks guys!
My rig is a Trooper T2 1100
    • By Frank in MI
      Thanks for accepting me!
    • By SouthernGypsy
    • By se3388
      Steve.............
    • By Texjpr
    • By mark walkom
