2010 POLARIS RANGER 800 XP 4X4 IN EXCELLENT CONDITION. GREAT LOOKING FROM END TO END.
800 CC LIQUID COOLED TWIN CYLINDER ELECTRONIC FUEL INJECTED ENGINE. LOW MILES 1264 AND 112 HOURS.
FULLY AUTOMATIC TRANSMISSION WITH HI/LO AND REVERSE. PARKING BRAKE. PUSH BUTTON FOUR WHEEL DRIVE WITH LOCKING REAR DIFFERENTIAL.
HYDRAULIC BRAKES FRONT AND REAR. INDEPENDENT SUSPENSION FOR AN EXCELLENT RIDE. SPEEDOMETER WITH ODOMETER, TRIPMETER,
HOURMETER, ELECTRIC FUEL GAUGE, GEAR POSITION INDICATOR, FOUR WHEEL DRIVE INDICATOR, ELECTRIC CLOCK,
AND FULL ONSCREEN DIAGNOSTIC DISPLAY. LARGE TIP UP REAR BOX. LARGE UNDER SEAT STORAGE COMPARTMENT.
GLOVE BOX STORAGE COMPARTMENT. 3 UNDER DASH STORAGE COMPARTMENTS, THIS THING HAS STORAGE EVERYWHERE!
OIL AND FILTER JUST CHANGED AND ALL MAINTENENCE GONE THROUGH FROM END TO END. CLEAR TITLE IN HAND.
FOR MORE INFORMATION AND PHOTOS PLEASE E-MAIL ME AT [email protected]
    • By boydog40
      thanks guys
    • By Jim Kessell
      2005 American Landmaster
      EH65 Subaru Robins
    • By Jerrys500
      Thanks Jerr
    • By Bjabbarw
      My 2021 Odes Dominator 800 bogs down at 25mph and won’t go over that speed. I have changed the fuel pump and it still does the same, it runs and idles fine, it has great reverse speed, but it won’t accelerate past 25mph. Any Ideas?
    • By vachi
      hi everyone i have this 2021 Hisun forge 250 that won't start. no spark no fuel.   when i turn the key on i dont hear the relays click or fuel pump come on. it does have power but the relay doesnt ground the pump or the ignition coil. dont know if there are any safety switches on this model or not.  it does crank and all the accessories work. i  hot wired the pump and it does work.  i found a wiring diagram but it's very hard to figure out and was hoping someone has seen this before. all fuses are good. thanks in advance.
