audio
charlie
hey everyone
most of you probally do have steros in the troopers now but if you dont check out BOSS atv stero tubes. you can get them on amazon for 140-150. They sound awsome I went and saw one on my buddys quad and it rocks. Its 2 6.5 speakers 2 tweater and 450 watts power hooks up with a cigerette lighter source or there is a lead that can go to battery then to system. Its marine grade stuff and all sealed up. You use an I phone or smart phone I pod and such. If you dont have a stero and have thought about it check it out I thought I had a nice stero till I saw and heard this thing
    • By onealmck
    • By mac66
    • By Ronald
      Check engine light comes on after engine runs continuously for 5 minutes or so.  I can shut down the engine and restart and check engine light goes out, then comes back on after running 5 minutes or so?  What ya think?
    • By sxr951
    • By Jhud
      In the market for side by side. Narrowed it down between the pioneer 1000 or defender Hd9. Looking for pros and cons of both. Any info would be helpful in my selection process. Noise, speed, reliability, ride, all of it.
