  • Replies 36
  • Created
  • Last Reply
Top Posters In This Topic
New rear SwayAway air shock is here and installed. I did some adjusting last night and waiting to hear back from company now on some tuning tips seem a little stiff but I had it set that way easier to adjust down then up lol. I will update with pictures and ride update. On another note if any one is gonna go this route I would probally recommend SwayAway on all 4 corners I still have my fox 2.0 in the front and may change them to the SwayAway. The sway away just looks better and I really like how the spacers are made to go inside the mounting hole and space the shock properly
  • 5 years later...
    • By Grant
    • By SpaceGhost
    • By JSwearer
      Does anyone have any suggestions for aftermarket shocks.  I have a T-Boss 550 and took it riding in some rough trails and the stock suspension was uncomfortably rough.
    • By redneckred
      I have a 2012 Bennche Bighorn 700X.  I bought it used.  It had been sitting in a field for several years untouched.  I put a new sun gear in the shifter, new shifter linkage due to the old one having been patched, and a new battery (and of course fresh fuel).  The machine cranked and ran beautifully.  I had it over a year and then the machine quit running.  As it would not stay cranked, I narrowed the problem down to a bad IAC valve.  I replaced it and it ran as good as new/old.  Fast forward, the machine started to act like reverse wasn't catching and would not always back up when in gear.  Then forward quit.  I assumed a bad CVT belt and got one.  Started removing the bolts from the cover and (3) just turn in the housing without coming loose.  (2) are on the bottom, so very little room to do anything with them.  I tried cranking the machine again to see the belt move since I can move the cover enough to see the belt and now the machine will not crank.  It turns over fine.  It gets gas to the injector and has spark.  I can spray cleaner down her throat and she would run until it ran out.  I have replaced the IAC twice and put a new injector with no change.  I went out and put the old injector back in to see if that made any difference and, well, it did.  I tried to crank the machine and the starter is stuck trying to turn the machine over even with the key off.  I have to disconnect the battery to stop it.  Before I shoot this thing, what am I missing?  Is this an ECM problem or something else I am not seeing?  Been dealing with these Gremlins for over a month now and weeds are starting to overtake the motor due to it not moving.  I would love to get the thing running first and any ideas of getting those CVT cover bolts out would be extremely helpful.  Thanks in advance.
