EZ Fit Camo Kits - Pre-Cut Exact fit UTV Camo Wraps
By mac66
By sxr951
By BernieG
The second item is this vacuum valve looking thing. Again only one line is still attached. What is it's function and what other lines should be connected to it?
Any help the community could provide would be greatly appreciated. This UTV belongs to a friend, and I am trying to help him get it running correctly for his kids.
By AndySwish33
Brand new t boss 550. couple of questions.
1. Do you need speakers in order to play music ? Hooked my phone to Bluetooth no sound
2. On screen registration.. it won’t let me fill in the info on the touch screen. Navigation works but the registration portion does not
3. Is there a data plan you can get or need ?
thanks everyone
By Rizzguy
Don’t waste your time everybody with rpm motorsports, Omaha. They are people that don’t even work on sxs’s. Trying to tell you how to install things.
Completely uneducated guy tried to tell me I did not install a mid pipe correctly when it won’t install correctly; that was the reason for the video and the complaint that I called him about.
This mid pipe has a 1 inch gap at the rear, and the only way to close it up is with a longer bolt, and to stretch the flex at the Exhaust
After one ride, the rear bolts have disappeared, because how much tension there is on the flex
And the bolts does not line up at the flange
Have a video before and after. And they are telling me that it’s my fault because it does not fit
wtf.!
What kind of idiotic people are even answering the phones these days.?
This guy has probably only read a book and never even driven a motorcycle in his life
Don’t waste your time with this bullshit products
