New intake manifold for trooper
By Edelbrock
Thoughts?
By Paul L
When I am driving at 30 to 40 mph on the highway, the display will change from H (high) to R (reverse). It does not actually shift into reverse, it seems to shift into neutral and starts losing speed and the gas pedal has no effect. After the rpm/speed drops for 5 seconds or so, it changes back to H and runs fine for another minute or so. You have to try to drive it at less than 5000 rpm or so, to try and keep this from happening. Any ideas on what the problem might be? It only happens at the higher speeds.
By CYJSP2009
Dear Joyner owners
3. Cables,
4. Brake parts
5. Engine parts
6. Other parts.
Have a good weekend
Casey / Leaf Asia
2023-11-17
I've been having misfire issues with my UTV 400 when it gets warm and I've thrown all kinds of parts at it so far with no permanent resolution. Today I removed the O2 sensor and it is black on the end. To me that means it's running rich and/or the sensor isn't working. I replaced the sensor with a new one and will see how it goes I guess. With EFI, I'm wondering why the sensor would be this way with low hours and mileage? Is there a way to adjust or lean out fueling on these? Thanks in advance.
By Bobbers
