Whazzuuuuuppp fellow utv'ers
crashjunkie1980
    • By Kingfish
    • By WCF
      Hi Joyner Gang
    • By Paul Angstadt
      Paul
    • By Venom
      I picked up an old beat up 2010 American Sportworks Bull Dog 300 BD300.  I would like to restore her...  Does anyone know a good source for parts other than the OEM?  I find $130 for brake pads is kind of unreasonable... I also need a steering rack and other things... I took apart the steering rack and it needs a new bearing and oil seal... Of course the OEM only sells the complete rack for over $200..  I found the correct bearing for $6.00. I am having trouble finding the correct oil seal..
      Anyone that has info on one of these machines, please chime in...  I am used to the ease of finding info on Polaris, Honda, Can Am, Kawasaki, etc.....,  Info and parts on these seems to be scarce..  Some of the parts on it look like Golf Cart parts as well as some look like Go Kart parts..
