Speaking of Turbo Kits... here is what i can do..
Non Inter cooled
-CF K03 Turbo
- 4-8 psi Waste gate
-Turbo manifold
-Carbon Steel Mandrel bent piping
-Billet Blow off valve
-Fuel Programmer with boost port
-Turbonetics boots & T-clamps
-All stainless steel braided oil feed & return lines & fittings
-Turbo muffler and exhaust piping
-Auto Meter Ultr-lite Boost/Vac Guage
I can do this kit with a 1 Yr warranty on turbo for $1950 shipped
Inter Cooled
Same as above with Mishimoto Inter Cooler
-all bracketry for mounting
-8-12 psi waste gate
- 19 lb/hr injectors
I can do this kit for $2500 Shipped
is there anything else you guys would like to see included in these kits?
I should have one shipped to Nocturnalsixer soon for a review and quality and performance
also i will offer my intake manifold with the turbo kit for an a additional $400 if ordered at the same time.
Josh
No Limitz
    • By staind
      thanks Dan D. aka staind
    • By BMurph
    • By BMurph
      Picked up an essentially new 2022 UT400 with 9 miles on it.  Decided to change the oil because it's probably never been done.  Pulled the dipstick and noticed it was overfull then went and pulled the drain plug and took off the filter and it was like brown water running out.  What should I start checking?
    • By Cory J
      Belt started slipping when I used it in high gear. It works okay in low unless I'm trying to power it up a hill and then it slips.., Ordered a new belt and went to change it and found a good bit of oil in the belt housing. Has anyone experienced this? Belt looks fine. Only have 300 miles on this thing..
