Speaking of Turbo Kits... here is what i can do..
goindeep
Non Inter cooled
-CF K03 Turbo
- 4-8 psi Waste gate
-Turbo manifold
-Carbon Steel Mandrel bent piping
-Billet Blow off valve
-Fuel Programmer with boost port
-Turbonetics boots & T-clamps
-All stainless steel braided oil feed & return lines & fittings
-Turbo muffler and exhaust piping
-Auto Meter Ultr-lite Boost/Vac Guage
I can do this kit with a 1 Yr warranty on turbo for $1950 shipped
Inter Cooled
Same as above with Mishimoto Inter Cooler
-all bracketry for mounting
-8-12 psi waste gate
- 19 lb/hr injectors
I can do this kit for $2500 Shipped
is there anything else you guys would like to see included in these kits?
I should have one shipped to Nocturnalsixer soon for a review and quality and performance
also i will offer my intake manifold with the turbo kit for an a additional $400 if ordered at the same time.
Josh
No Limitz
    • By Wesley
      I have a 2022 500 Hisun product, I have had them in the past. I change my oil myself and trying to drain through the hole where I remove the plug is a mess.  How does everyone keep the belly pan clean during the oil and filter service?
      Wes Jackson
    • By amiracle40995
      I've never seen the temperature go high on this thing. the fan runs almost all the time even though the sensor is  reading at the very bottom of it's range. ive taken the cylinder head off.  (nothing definitive but maybe a little fuel on top of piston with oil in it.i don't think this has anything to do with my problem )head gasket is 3 layers deep and I noticed some grit that might have been in between layers but nothing to say the head gasket wasn't intact.  black carbon build up on piston. I've looked all over the head for cracks from over heating. I'm about to look again for hairline cracks that are extremely difficult to see. my buddy helping me said to order rings in case they are letting oil pass thru he also said get a new head gasket.. I'm looking at water in oil first and I'm not ordering rings. I haven't checked the oil cooler to see if it's defective yet.  I'm just hoping someone had a similar problem. my only problem so far has been having to change the spark plug every 100 miles with 93 octane run thru it.
    • By Mark in Idaho
      I know this sounds like a dumb question, but I just got a new Hisun 550 strike and I cannot find the oil dipstick to check the oil level.
    • By Alex
      Explore Kemimoto's CFMOTO accessories collection that will elevate your riding experience. From protective gear to performance upgrades, they offer everything you need to customize and optimize your CFMOTO vehicle. Kemimoto has bags, boxes, bumpers, covers, camera mounts, cup holders, doors, and more! Outfit your CFMOTO today!
    • By Retired Plumber
      The rear differential lock light is on and I would like to get it off. How do I do that it is a Coleman UTV700.
