Not sure if you got your front rims or not, but I was looking for a spare and found these.
http://www.powersportsplace.com/parts/sum-161-147115m4/overview/
The back spacing is same, 4", bolt pattern same, 4x115, offset is slightly different 4+3 vise stock at 4+2 ( I think, correct me if I'm off on that) but it should still work. I haven't been able to check the hub bore to make sure it would be big enough, but that is just a quick measurement of the hub to make sure it's less than 70mm dia.
They have other wheel options that should fit as well, I just liked the price tag on these since I am only looking for a spare.
    • By Karlibob
    • By Marie
