I have been searching the Chinese market on master cylinders in general, getting close. One thing I have been finding is most of the parts on these are directly off import cars, quad's and motorcycles. Just havn't found the exact bolt pattern yet. Left messages at 3 dealers in Az but no one responds. Thought about maybe installing a line lock like they use in drag racing for a parking brake option.
My parking brake master cylinder failed and I was lucky enough to get one from a friend to replace it with, I think the problem with them is that the plunger is not protected from the element by a boot or anything else. May I suggest the every one put a piece of foam rubber around the shaft to help keep out the dirt and moisture.
Good luck with your search, let me know if you find something and I'll add it to parts and pieces.
    • By Brett
       up.
    • By Jerrys500
      Thanks Jerr
    • By Gorj
      I have had my E1 since late last summer and I have always noticed that the parking brake was weak or non existent. About a month or so after I purchased it I mentioned to the dealer that the parking brake did not function well. What I was expecting from the dealer, ' well bring it in and we will correct the issue.' What I got was the typical dealer response, "it may just need to be adjusted." No shit!  Well I finally decided to adjust it. A very simple process need only two 10mm wrenches.  Open the bed, remove the pin holding the bed  to the strut and move the bad out of the way. Right in front of the electric motor is a brake disk.  That is the parking brake. It has a small set of brake pads that are actuated by a lever attached to parking brake cable.  There are two 10 mm nuts on the shaft to moves the pads. Release the inner nut and hold it in place while screwing in the outer nut - that is really a bolt. After screwing it in about one turn, tighten the other nut.  Check the parking brake. If it is holding when activated, then you are good, but if not, then you may have to turn the bolt another turn. Do not turn to far or you will lock it up.
    • By SouthernGypsy
