Installing Turbo
By Prepper
I have been doing a little research on which engine oil is best for UTV engines. There seems to be some disagreement over using a good quality regular engine oil, and the necessity of using "M2" (or wet clutch suitable) oil. My understanding is the "wet clutch" suitable oil has less friction reduction properties (hence a more responsive clutch with less slippage). While less friction reduction properties would seem to be better for the wet clutch... it would not be best for the internal engine parts like camshaft bearings and other moving parts where friction is detrimental and would lead to premature failure. Some folks swear you need M2 oil, while others say they have been using regular motor oil for years and their clutch is just fine. Could they both be right ???
Any thoughts ?
By aefron88
By Paul L
When I am driving at 30 to 40 mph on the highway, the display will change from H (high) to R (reverse). It does not actually shift into reverse, it seems to shift into neutral and starts losing speed and the gas pedal has no effect. After the rpm/speed drops for 5 seconds or so, it changes back to H and runs fine for another minute or so. You have to try to drive it at less than 5000 rpm or so, to try and keep this from happening. Any ideas on what the problem might be? It only happens at the higher speeds.
By Marie
