I'm looking for a Transmission. I have busted the housing, and u joint and not sure what else yet, it will get disassembled in the next couple weeks. Baja 1000 is first, but looking to find out what anyone has if I need it.
Thanks Casey
All a few weeks ago I inquired about a tranny for a 2008 Joyner t4
Well I have the tranny disassembled and this is what I need. Do any of you have these items. I took the reference number from the manual. Everything thing else is perfect still
I will be looking high and low so I don't have to buy a new tranny.
Ref #. Part#. Description. Qty
1. QR512---1701101. Clutch case 1
2. 4T08A1---1701111. Transmission Case. 1
29. QR512---1701710. Reverse. Gear. 1
46. TR1100.03.03.02.00. Rear inboard slip drive. 1
Kinarfi,
On the how not exactly sure. When it actually snapped I was flying down a graded gravel road. I do have the 2008 version with the U Joint, will go to the CV.
Over the last years, I have used the trooper as a chase car here in Mexico where I live. It has seen the toughest environment possible. I'm continually pushing it to the limits through deep woops, deep sand and silt, salt water washes. It has been a trooper no pun intended. I'm sure the miles of bottoming out on rocks hasn't helped either.
Kinarfi,
Used like a police car? Sounds like tons of fun id probably enjoy that job lol
Nocturnal:
Not like a police car. Desert racing, so we use it for pre-running, and during the race I carry parts, tools etc to help if the team breaks down.
Your point sounded cool though.
Nocturnal:
Still fun, i was thinking border patrol lol....
Also while i was thinking about what u said about Honda engine...i was considering the gm 3100/3400 or 3800 60° v6 with 4t60e transmission in trooper because in usa/Mexico those are very plentiful.
Then we would have to get the Ford 7.5" diff from goindeep or build or own diffs or go with a full solid Dana 30 35 44 whatever or for front axle...use a Chevy front 7.5/8.5 diff out of a s10 or full size and the rear diff out a t bird with 8.8 ring or something..that would be overkill i imagine lol
EDITED: Dethobica, was you planning on going with a manual or automatic transaxle?
4T60e is front wheel drive overdrive transmission used in gm fwd cars, vans etc from 90's up to recently, same thing for the engine mentioned
    • By ToughLuck
    • By Steve Waldner
    • By CYJSP2009
      Dear Friends,
      Buy 1 piece: Get 5% discount,
      Good Luck
      Casey / Leaf Asia
      July-07-2022
    • By tuell
