T4 2008 Transmission
Detbohica
All a few weeks ago I inquired about a tranny for a 2008 Joyner t4
Well I have the tranny disassembled and this is what I need. Do any of you have these items. I took the reference number from the manual. Everything thing else is perfect still
I will be looking high and low so I don't have to buy a new tranny.
Ref #. Part#. Description. Qty
1. QR512---1701101. Clutch case 1
2. 4T08A1---1701111. Transmission Case. 1
29. QR512---1701710. Reverse. Gear. 1
46. TR1100.03.03.02.00. Rear inboard slip drive. 1
Kinarfi,
On the how not exactly sure. When it actually snapped I was flying down a graded gravel road. I do have the 2008 version with the U Joint, will go to the CV.
Over the last years, I have used the trooper as a chase car here in Mexico where I live. It has seen the toughest environment possible. I'm continually pushing it to the limits through deep woops, deep sand and silt, salt water washes. It has been a trooper no pun intended. I'm sure the miles of bottoming out on rocks hasn't helped either.
Kinarfi,
Used like a police car? Sounds like tons of fun id probably enjoy that job lol
Nocturnal:
Not like a police car. Desert racing, so we use it for pre-running, and during the race I carry parts, tools etc to help if the team breaks down.
Your point sounded cool though.
Still fun, i was thinking border patrol lol....
Also while i was thinking about what u said about Honda engine...i was considering the gm 3100/3400 or 3800 60° v6 with 4t60e transmission in trooper because in usa/Mexico those are very plentiful.
Then we would have to get the Ford 7.5" diff from goindeep or build or own diffs or go with a full solid Dana 30 35 44 whatever or for front axle...use a Chevy front 7.5/8.5 diff out of a s10 or full size and the rear diff out a t bird with 8.8 ring or something..that would be overkill i imagine lol
EDITED: Dethobica, was you planning on going with a manual or automatic transaxle?
4T60e is front wheel drive overdrive transmission used in gm fwd cars, vans etc from 90's up to recently, same thing for the engine mentioned
    • By Alex
      This is an interesting read. ADAS is main stream on cars these days. The technology looks to be headed towards UTVs and Off-Road Vehicles.
      Potential Motors and CFMOTO USA have announced a new partnership to integrate advanced driver-assist systems (ADAS) into recreational off-road vehicles for the first time.
      Sam Poirier, CEO and co-founder at Potential Motors, says the integration of its technology into CFMOTO’s vehicles will set new standards in the side-by-side segment. (Photo: Potential Motors Inc.) The partnership will first see Potential’s tech integrated into CFMOTO test vehicles. The companies will conduct extensive real-world testing at Potential’s purpose-built off-road proving ground in Fredericton, Canada, and CFMOTO facilities.
      Source: https://powersportsbusiness.com/top-stories/2023/12/19/cfmoto-and-potential-motors-announce-industry-first-adas-technology-for-ohvs/
    • By mac66
    • By sxr951
      2015 massimo 700.. need cylinder bolt!  it some special cut from factory,, its a 125 thread but its like between 8 and 10 mm  dont know where to find any ideas? thx
    • By sxr951
    • By Stan Morton
      My 2018 XG-850-SL starter died yesterday. The old part number from Kubota is E7153-11732 which has been superceed by part # EG881-63010. I am looking for an aftermarket starter because the Kubota retail price for the starter starts at $550 and upwards toward $850.  If anyone has gone down this road before and has found an aftermarket starter ~ please share with me. We own a ranch and this thing is used every single day and is sorely missed when it is down for maintenance.  Kind Regards, ~ Stan
