Crankcase evacuation
huunz
I've been messing with my 650 Sand Spider for a couple of years now, and have gotten a lot more power out of it. I added a Fast Freddie Weber 45 DCOE kit, modified the header, tried a remote filter setup (didn't work), put long travel Fox Airshox on it, lightened the frame, jusat generally did a lot of old time hotrod tricks.
One trick i did was a crankcase evacuation setup. I'm out at Dumont now, and it sucks all the oil out of the engine through the exhaust pipe - it works too good! Now I need a new valve cover for a 650 Sand Spider (2 cylinder). Anyone?
One trick that did work - I port matched the entire intake. I put rags in the head to keep the debris from falling in, and gently ground out the bores until it was all smooth and clean. Big change! The intake ports were very "dirty", with a lot of random casting slag in the port itself.
Anyway, looking for a valve cover.....
No, it sucked the oil out into the header, where it burned/smoked, and made it look like an old 2 stroke. I stopped testing before I lost oil pressure, although I burned out about a quart over the weekend. I'd let it go down a half quart, then refill.
If I hadn't stopped, it would have probably sucked it all out. It also didn't let the oil in the upper end fall into the pan, so I lost oil pressure on and off after hard runs.
On the plus side, the new suspension is awesome, evening out the whoops and soaking up bumps, so the ride is very safe feeling. I was ripping the dunes pretty well. The mess on the lens is oil that spewed out and I didn't catch until I watched the videos.
    • By Goat Quilter
      We pout new belts cleaned engine and carburetor plugs you name it.  Drove down road no problem came back uphill no power won’t go . What’s the issue?
      could it be clutch?
    • By Goat Quilter
      New belts and engine cleaned and checked carburetor cleaned drove on flat ground fine turned to go up hill lost power wouldn’t go
      Could it be clutch issue??
      so frustrating this thing has been in shop more than used on our farm.
    • By GWS
    • By mac66
      I added lights to the Coleman Outfitter 550 last fall.   I bought lights on line from Nilight, a 300 W  12" light bar mounted forward and 2 square 4" floods for the rear.  Those are mounted on the roof corners facing rear and downward just beyond the tailgate.  Nilights seem to be of high quality, as I've had them on my garden tractor for 5 years and still flood the way ahead with great light.
      Both the front and rear lights provide amazing illumination making the OEM headlamps look like parking lights.  Made a connector for the front bar that plugs into existing headlamp switch so it is just part of that circuit controlled by the headlamp switch.   Rear work lamps were wired in using a rocker switch installed in the dash.  Backed up to the garden with the work lights and was able to harvest some tomatoes well past sunset.
      What have you used if anything for auxiliary lighting on your UTV?
