1974 2.7L Porsche 911 Coupe
By Gorj
I am into five years of ownership of my electric side by side and I am noticing some deterioration of power. Although I measured the voltage at over 49 volts, I believe the batteries are beginning to fail. I charge them about twice a week. Last year the charger went out and I replaced it with a 48 volt golf cart charger. What has been your experience with the batteries?
By Roadstar515
Regards, Rick
By Greg Kilgore
By mark walkom
By Fishing Wiskers
