Well now i could use a lil help... i have a trooper in my shop now that has wiring issues... this poor guy paid another shop $1000 to re wire the body control harness, and boy oh boy did they chop it up!!! I am Buillding a new harness from scratch... what i need is a diagram that tells me what each fuse and relay control on the Engine fuse/relay block.. any help is greatly appreciated!!
Josh
No Limitz
Josh
No Limitz
Text sent...i have been down this road i could help you
Brandon
  • 4 years later...
  • 6 years later...
    • By Dennis
    • By Marie
    • By Marie
