Air filter part number for 2020 Tracker 800SX
Go to solution Solved by Pilot1996,
  • GWS changed the title to Air filter part number for 2020 Tracker 800SX
Got it. I would think that if an inner filter was bungled with this filter it would fit. That may be wishful thinking.
    • By Jim Kessell
      2005 American Landmaster
      EH65 Subaru Robins
    • By Texjpr
    • By shawn b
    • By Gary Gallo
    • By Paul in Wisconsin
      I have a 2023 Tracker 800SX LE that I want to add a sway bar to.
      The service manual shows how to remove and reinstall the sway bar.
      I called Cabela's to try and get the saw bar.   They said they can't get one and the 800SX doesn't have one!!??  Then why is it listed in the service manual?? No answer from them.
      Have any of you found a saw bar that fits and what did it cost?
