Silverbulletmotorsports will be open in a week or two.Jose is no longer in busness.We need to sort out a few things.And we will be up and running.We have a temporary # 928 247 3087 for now.We have parts in stock and on order.
Thank You
Frankie
What about orders that where paid for and not shipped or received I ordered 2 diff kits for a trooper in nov.
If parts were paid for with credit card.Call bank and tell them you want to dispute charges.
If you paid by pay pal dispute charges
Thanks Frankie
Silverbulletmotorsports.net
Temporary phone number 928 247 3087
Hi I am new to this form and I would like to know your actual address for Silver Bullet Motorsports.
I have search and I have two addresses. One on 2/ 1/2 e Street and one on East Palo Verde. Which one is the correct address?
Silverbulletmotorsports is location will be 720 E 39 Pl suite 4
Yuma Az 85365
I have been working with a new Joyner shop in Mesa AZ. I went there and picked up axels, shocks, bearings, throttle cable. They have a complete line of parts and Machines. I have also ordered parts from them with great customer service. Appears to be a reliable contact for stock parts.
The address is 8743 Pecos RD unit 123 Mesa AZ 85212. PHONE 480-882-9612, FAX 480-888-1005.
Operations manager Kris Abel phone 480-238-9015
It's hard for someone to take over a company that has not given good service. Jose is gone and Frankie starting to make Silver Bullet a reliable business.
I think it would be nice if you guys will give Frankie at Silver Bullet a chance to show that he will make good on orders.
I bought 2 rear swing arms at a great price and S/H.
Had them at my home in 4 days and at a good price.
Frankie,
Jose did some work on my Joyner and it didn't turn out right and he had me take it to another mechanic to make it right. i see that he no longer owns Silverbullet. Can you pm me to go over details.
    • By SouthernGypsy
    • By se3388
      Steve.............
    • By Jon V
      Good afternoon. When the timing chain came off its lower gear (previous owner had over-tightened the tensioner), I ordered new parts.. chain, oil-pump chain, tensioner etc.. But now that it's time to put it back together, the main crankshaft makes a clang noise and stops when you turn it by hand. I want to solve this before assembling everything. The camshaft cover is off so that the valves aren't being activated. Should the transmission be in neutral to turn the crankshaft? The engine was running fine until the chain came off the lower gear. Then it would spin when the starter motor engaged so I assumed the crankshaft was spinning. Any advice is appreciated.
    • By mac66
      Apparently, these are Hisun or at least they use Hisun engines. I can't find much info on them online yet.  Ran across a used one with just 100 miles on it as a very reasonable price.  Just curious.
    • By sxr951
      corrosion had its oring neck area  jammed in.. and besides that had corrosion in the starter just shorted when ran direct jumper cable to the starter post power to it
