just waiting for some more LEDs and lenses of the correct value to put in my latest Project, this ought to out shine the stock over head light. Just hope it doesn't get too hot.
photo removed, needed the space elsewhere, Kinarfi
Trying to stay warm!
rocmoc n AZ/Mexico
Hi Mike,
Is that really a big problem in AZ, Right now, It's snowing here, as I sit watching TV from my recliner, all covered up with an electric blanket and shawl around my shoulders and computer on my lap. :) What a life
Next big project will to tear out my dash and put in an aluminum one with different gages and all switches in nice clean rows. I will model it on the computer first until I like how it looks and go from there. It will be designed to hinge so it can be opened up from inside the cab. Its awfull to get at and see everything clearly from under the hood. I will probably add some gages too like oil temp, exhaust temp, air tank pressure. I will also probably put in a row or two of LED lights with each one hooked to the fused side of each fuse so if one goes, I will see it right away and anything else I can moniter. Wife wants some doored cubbys to put things in. Maybe a heart moniter for my wife for when I hot rod it like we were doing at the last Jamboree.
PS; almost rolled it the other day. Wife said " DON'T YOU KNOW YOUR FRONT LEFT WHEEL IS ABOUT 4 FEET OFF THE GROUND? "
this is what I am tlking about its better than reading help help help. Good luck on the dash Lenny Im sure it will be awsome. Kinarfi send the snow my way its 63 and raining here ugh
You should have told her not to worry unless the left rear wheel also was 4 feet off the ground.........
    • By SpaceGhost
      Hello All...
    • By Tarak1980
