New belts and engine cleaned and checked carburetor cleaned drove on flat ground fine turned to go up hill lost power wouldn’t go
Could it be clutch issue??
so frustrating this thing has been in shop more than used on our farm.
    • By SpaceGhost
    • By Croppy38
    • By camojay
    • By weasel
    • By Cletus
