05' Crew style , 4X4, 620cc motor.
No Vins stamped or any Stickers on Frame ( Front Frame, side Rails or engine area tube or flat panels ??
Where do they hide the Vin #'s ?
All i can find is a sticker on the motor / engine ( Mfg. Date 0705 ) ??
  • 2 months later...
Mine is on the vertical tube next to the radiator on a small plate welded to the tube, on the drivers side. Unfortunately, it is also where the radiator cover rubs and it's made it hard to read. I sanded it off, wiped on some black paint and then gently wiped the paint off of the surface so the paint would hang in the stamped Model/Serial number.
    • By Gary Odom
    • By Karlibob
    • By Duane Baker
