i ohmed injectors their good none of them leaking passed fuel pressure 50#. took intake off cleaned it all. massair cleaned? is their an ajustment on throttle posipioning scensor? i'm not shour what to do next. rich 10-11 on gage
Don't think u can adjust the throttle position sensor check ur throttle plate in throttle body make sure it's not gumed up with carbon, try idle screw and u could have a bad o2 sensor in front of cat converter
changed o2 cleaned plate airfilter new plugs. the only thing differnt i pluged vacum line going to valcover.
    • By weasel
    • By Jim Kessell
      2005 American Landmaster
      EH65 Subaru Robins
      Have an issue all the sudden where the UTV will cut out randomly mid range throttle and under load.  Light consistent throttle on fairly flat ground no problems.  If you quickly change throttle position sometimes it will bog down and cut out, splutter, etc.  Floor it or let off and it may do just fine.  Going up a hill and adding more throttle as the incline demands, will cut out splutter and smell unburnt fuel.  So far doesn't ever completely quit.  If you let off it will idle just fine.  A lot of times if you floor it, it will pick up and even get a boost of power.  Changed to a slightly hotter plug to see if that would make a difference, but it didn't .  Any ideas what might be going on and what to try next?
    • By TexAcoon
      I'm looking to purchase a 2015 Massimo 550 that might have an issue with it's throttle position sensor.
    • By Buddee
      2010 Hisun 500 - Carbed'.  She sat for about 3 weeks since last use.  Couldn't get it started.... has spark but plug was not wet.  Bought new plug, cleaned the carb, confirmed fuel pump (pulse type) is working.  Still nothing.  Put gas in the plug hole.... started right up and idled as normal and drove perfect.  Used it for the rest of the day without issue.  Tried to start again next morning.... same problem.  Poured gas in plug hole again.... started up and best kind again.
