Dang, you got a strict trail width restriction! +1" total width is a game changer? What about the rears, did you make them narrower or decrease backspacing to fit on the trail? I thought the way they were setup from stock the rear sat wider..... or maybe that was my oversized tires squeezed onto the stock rims.
the wheels that came on mine it's 64" wide. i have some steel car wheels that are heavy that makes it 60" wide. the trails we ride in KY. ARE MARKED 58" LIMET. i can get through at 60" and it rubes both sides in some places an hangs on edge of big cliffs some places so yes it matters. front end spindels are wider then back.
U got t2 through that narrow gates!? Ill like to know how too because gates here are also 58-60" and wouldn't accept anything wider
What car did your wheels come off of? Wish I had some advice, but I don't?
Yes I do, My son has an RZR4 and the trailer he is using is too narrow for it, so he runs a ratchet tie down strap from A arm to A arm and cranks it up so that it is narrower and rides higher, perhaps you can try the same for areas that need to be narrow.
older mitsubichi car wheels from junk yard
Haha if I don't fit I just find a way around
not were we ride theres not rume to turn around you will back up for a mile or two if lucky. some times you can't make the corners going backwards the front wheels fall over the edgeh half to winch back over to get around corners. pretty tight.
hey plumber going their riden march 21. you whoun't to go. we go to willey beagley camp grounds an ride dainel boone forstry
Hey Dave it's so hard for me to plan something I'll let you know when it gets closer. I need to go it's been awhile since I been riding.Is it a 60" wide restriction my trooper is 64" wide
they been maken them wider a lot of rzrs been going their you'll make it tight in spots.
    • By Karlibob
    • By Robbie Wyre
    • By JSwearer
      Does anyone have any suggestions for aftermarket shocks.  I have a T-Boss 550 and took it riding in some rough trails and the stock suspension was uncomfortably rough.
    • By KimAC
      I need a pair of front shocks for a Landpride Treker 4200NT, from 2005?  Does anyone know of a good salvage yard - or another source?
      -Kim
    • By FGT
      QUESTION: How to wire the C/B into this current dual battery set up.
      EXISTING SITUATION: MAIN Battery is OEM and feeds OEM circuits. Added an AUX Battery in the OEM dual battery location. Connected the AUX - terminal to the MAIN - terminal. Connected the 100A Accessory Fuse Block power cable to the AUX + terminal. Installed a smart isolator between AUX and MAIN batteries where a cable from AUX + goes to the isolator and a cable from isolator to MAIN battery + terminal. Installed separate QD battery tender cables to both AUX and MAIN batteries + and -. The dual battery system appears to work as intended. For this Phase 1 improvement, to avoid having to constantly pull the leads on the AUX + battery post off and put on, for testing or maintenance of Accessory circuits, I wanted a more convenient and safer way to open the circuit from the AUX battery + terminal the Accessory Fuse Block. I called an off road dealership and was told to install a much larger capacity circuit breaker than the 100A rated Fuse Block and was recommended to get a 250A C/B like the one in the pic, which I did. I was told the reason for the C/B high amp rating was two-fold (a) to trip in the event of a battery short circuit and (b) to be able to conveniently open the C/B to kill power to the Accessory Fuse Block without removing leads from the AUX + terminal. The 250A C/B has two posts labelled "BAT LOAD" and "BAT LINE". There are currently three connections to the AUX + post: (1) Accessory Fuse Block power cable, (2) cable to Isolator AUX in terminal, (3) cable from AUX battery charger.
