Un able to locate fuses for the front diff in a 06 commando, I haven't pulled the roll cage or hood yet to really get in there with a flash light. I read somewhere it should be under pass seat but the only one I found was an inline for main power to dash. Front Diff doesn't engage and no clicking sound.
#2 S11-3605010TA R2/R4 800 372ECU 1 561.35
#2 S11-3605010JA Trooper ECU 1 709.10
. If you look at the numbers the last two number are different so I would say yes they are different
    • By Karlibob
    • By Edelbrock
      Thoughts?
    • By aefron88
    • By CapnWalleye
