OK fellow Joyner people! I have a Renegade R4 in the shop right now. The man brought it to me as a "no start"... he said he went trail riding and got it stuck very bad, he left it overnight. The next morning went to get it and it wouldn't start.. he drug it home and somehow came to the conclusion it needed a new ecm... he gets a new one hooked it up and still no start... this is when I get it.. the ecm is laying in the floor and the two ground wires are not hooked up.. I ground the two wires and boom it starts up.. but only running on two cylinders. From what wire diagrams I can find the trooper has two coil drivers and the renegade has three. I have checked the coil and all the wires and all is good. I am not getting pulse from the ecm for the third coil... the old ecm cover was sitting in the floor so I compared the numbers, totally different! Called the place he ordered the ecm from and they are telling my the old number superseded to the new one I have. I checked the ecm on my trooper and the numbers match perfectly. So what I am saying is the new ecm they sent is a match for a trooper ecm... are they the same?
Thanks for any help!
Josh
Josh
If the numbers are the same, they are for the Trooper and that would explain the running incorrectly. Otherwise, the ECU looks for information from the tach and cam positon sensor to initiate spark. You might check there for a bad connection. Make sure your grounds are solid to the engine and ground the exterior of the ECU.
#2 S11-3605010TA R2/R4 800 372ECU 1 561.35 #2 S11-3605010JA Trooper ECU 1 709.10
I would say yes they are different the last two number are different and the price are different
    • By CYJSP2009
      Dear Joyner owners
      3. Cables,
      4. Brake parts
      5. Engine parts
      6. Other parts.
      Have a good weekend
      Casey /  Leaf Asia
      2023-11-17
    • By CYJSP2009
      Dear Friends,
      Buy 1 piece: Get 5% discount,
      Good Luck
      Casey / Leaf Asia
      July-07-2022
    • By Frank Mac67
      - NO CLICK - NO OTHER NOISE
      Can anyone help?
      Can anyone help with this?
