Zip open Windows
By Xov
By Unhappy Kioti K9 Owner
I own a K9 with 50hrs that has been in for repair more than once the farm. Multitude of issues, trying to file lemon on it but interested in knowing if owners are organizing for a class action suit. The dealer informs me there are “a lot of owners very unhappy with these”.
By FTG-05
By Grant
By didgeridoo
