Video Section
5 members have voted
  1. 1. Should we start a video section?
    • YES
      5
    • NO
      0
Do you think we could use a video section here at UTVBOARD? Basically to post videos from YouTube and maybe other sites. Maybe commenting as well. Currently we only have a photo section. Please vote.
    • By JOSEPH LAMAR
    • By joynersfuntillitbreaks
    • By Kingfish
