Hello, wondering if I could get help with a couple gauged not working. I replaced some bad gauges. Now I noticed that my oil gauge go all the way up when I turn the key on checked for bad wires. All look good. And another thing is my speed gauge won't move when I drive. It cycles when I turn key on and that's it. I have a 2008 renegade. Any ideas on this problem?
  • 4 weeks later...
Idk about speedo but I know the Joyners have issues with the oil pressure switch wich will lead u to think u have low oil pressure or bad gauge, I actually took my switch off and put a tester in I had little but more than factory quoted my gauge is good it's the switch
    • By Wolfpaak
      Kenny
    • By Aaron Colona
    • By Chile
      Chile
    • By Joe Breaux
