So what did you do for Earth Day?
By mcraigchr
Howdy y'all,
Craig C.
Can anyone advise if they have any knowledge of the jeep gladiator or wrangler with the 3.0 diesel? I don't believe they offer the diesel in new jeeps but I'm interested in a used one with the diesel. But wanted to hear how the engine performs.
By Gerals
