Hey guys went out today climbed a nasty hill hit a root kinda hard and steering wheel spun, now my steering wheel is way off is it possible it jumped a tooth in steering box???? Nothing looks bent and steering shaft is tight
Guest Lenny
I don't think you jumped a tooth but you could have spun the steering shaft on its spline. You might want to check the top cap on the steering box to see if it got pushed up, pulling the bolts out and allowing it to jump a tooth. If the cap is tight and especially if you have my steering upgrade, I don't see any way for it to jump.
Lenny thnx for reply I do have ur upgrade steering box. Steering felt fine just wheel is way off so what u are saying is the top cap at the pinion were shaft meets could have popped up and caused it to jump?????
I highly recommend you take at look at the splines on both the steering shaft and the steering box. If they are stripped the next time it will twist on an even less harsh bump and may knock out your steering all together. Next to new shocks, power steering was the best investment I made. I am able to drive with one hand through rocky/bouldery terrain. My friends in RZR's hate trails like that because they don't have power steering, but I don't mind them at all.
Finally fixed the steering had to replace pinion gear in steering box bought a shaft out of a camando it was shorter but I cut the end off plus three inches and welded it to my original boxed it and welded it seem tight and good now! No I just gotta get those dam bearings tight not loud just loose
  • 4 weeks later...
Nope no power steering unfortunately drives fine wheel is off nothing looks bent and I spot welded the steering shaft were they slide into one another
That is something I disagree with, although several have done similar things like put a bolt through it. I just make sure there is plenty of overlap and that the spring inside is greased and I added just a little more bend to the spring.
Another idea for fixing the u joint to steering wheel shaft if you have some spline left is to hack saw down the other side of slot, grind off the metal where the cinch bolt goes and put a U bolt around it to cinch it up tight. You might be able to find a small U bolt that is very hefty by modifying a steel cable clamp if you can find one that size, might be cheaper to buy a new U joint though and drill and tap it.
Just be sure that there are no wires that can get caught up in the steering. I had it happen once.
EEEK http://images.uscargocontrol.com/1754-1-drop-forged-style-stainless-steel-wire-rope-clip_1_640.jpg
$50 for a 1" cable clamp, don't think so!!!! I did find some for about 7.50 though.
Guest Lenny
I would just eliminate the spleen as a keying feature, Machine a heavy collar, at least 3/4" thicker then the shaft, to go over the shaft. Make it long enough so that 1/2 of its length can slide and weld to the lower steering shaft. Split the other half of its length it in half with two socket cap screws on each side so after putting it on the splined shaft you can squeeze it down real tight, clamping it. The loose 1/2 collar piece should also have two tapped holes thru it over the shaft, I used 1/4-20 . Then with the steering aligned correctly, pilot drill into the shaft about 1/8" to receive 2 more socket cap screws which key it to the shaft. I use socket cap screws rather then set screws because you can get them much tighter. I did this a long time ago and never again had a problem. It stays perfectly tight.
Trooper is gone so I can't take a picture.
p
    • By mhill
      Any thoughts? Suggestions?
      Thanks so much
    • By Cletus
    • By Steve Waldner
      I have a Kioti  Mechron utv and want to add power steering. Can anyone till me if there is an electric assist motor from a car that would work putting between the steering wheel and steering box. One that doesn't need alot of electronics
    • By Gerals
      Maybe all are aware of auction and equipment sales scams.  On another forum, I've done some research on scam auction sites for big ag equipment and have noticed that it has spread to autos and smaller stuff in the past year or two.   One was very sophisticated, including stolen IDs of known persons giving rave reviews of the auction site many going back several years to lend credence to the fake site.  The site was in fact less that one month old. The business address was a storage facility with no signage with a couple being just high rise office buildings.  The three I've looked into have used this three initials plus "auction.com"  format or similar.  "XXXauction.com". Ran across a new one 2 weeks ago in Craigslist.  Had some nice cars and trucks at auction, but visiting their auction site, the all too familiar red flags were all there and despite claims of 20 years in business the site was set up first week of November 2014.
      First big clue and giant red flag is the prices shown. Usually 40% of what the equipment is worth, maybe less.
      Red Flags:
      Prices are exceptionally low. Absurd delivery fees ie; 60 cents per mile, or $500 flat fee, anywhere in the US.  Moped or Army tank, all the same. Some buttons on site do not work. Auction closes shortly. Terms of payment always requires a wire transfer, no checks, no credit cards, only wire transfers. (Once a wire transfer is sent, there is no recourse, you can't get it back or get a refund). You get invoiced with remittance bank account numbers to wire your money to.   Photos are stolen from legitimate sellers or auctions. Often past sales and past auctions. Inability for you or your rep to inspect the machine.  Try calling and arranging an inspection, they won't do it for dozens of reasons.  These scammers award "winning bid" to literally everyone  who submits a bid. They send an invoice with remittance directions. Once you wire them money you even get a receipt. Then comes days of emails back and forth to set up the so called "shipment" of your equipment.  Of course that will fizzle out in a few days. By then your money is long gone offshore and you will not get it back or get anything for it.
      Just think of how lucrative this scam is.  Lets say a high end UTV all decked out shows on an auction closing tomorrow.   Nationally, they get 67 bidders all of whom get their "winning bidder invoices" and pay by wire transfer. Lets say average of $14,000 per bidder.  That's $938,000 on one fake auction UTV that no one will ever get.  Do this in 10 auctions in a week, do the math!!!
      I've seen agricultural  combines sold this way for around $89,000 to $100,000,  How many winning bidders...no one knows.  But multiply that by 50 or 60 winning bidders.  Get the point?
      Don't fall for this stuff, it is created, dies out, then gets recreated every 30 days or so.   Don't become a victim.
