Polaris Adds Youth RANGER RZR to Model Year 2009 Line Up
By Xov
By FTG-05
By SpaceGhost
They will be coming off.
By Prepper
Hello All...
Just bought a 2014 Massimo 500 UTV. It;s not running at the moment, but hopefully will soon. I need a seat for it also (passenger side, if it makes any difference.) It is a crank-but no start situation. Just now starting to read the boards for solutions. Apparently these models are well known for this issue. If anyone has any suggestions, please feel free to chime in, it would be greatly appreciated.
By Tarak1980
I have a Coleman HS400UTV-5 got it manly for hunting and spending time with the grandkids
The one problem I am trying to avoid. My son borrowed it last summer and said it ran hot so he added water to it . I do not know how much he put in so I would like to drain most of it and add new coolant to protect it this winter. I can find no drain cock or any way of draining it besides loosening a hose. Any suggestions ????
