Fuel Pressure
By onealmck
By jcbigg
When I try to start my AXIS 500 (from Lowes) there is a buzzing sound coming from the battery compartment and it will not turn over/start. The battery is showing 12.47 volts so that does not appear to be the issue, are there any suggestions on where to look next?
By Jason S
Good afternoon,
I have a 2022 Bobcat 34XL. Over time, I have to press harder and harder on the brake pedal before the ignition will fire. Now I have to practically stand on it with all my weight to get it to start. Does anyone know if there is a spring or something that might need replacing, or have had this issue before? I don't have any schematics of the brake sensor/assembly.
TIA
By BernieG
The second item is this vacuum valve looking thing. Again only one line is still attached. What is it's function and what other lines should be connected to it?
Any help the community could provide would be greatly appreciated. This UTV belongs to a friend, and I am trying to help him get it running correctly for his kids.
By Stan Morton
My 2018 XG-850-SL starter died yesterday. The old part number from Kubota is E7153-11732 which has been superceed by part # EG881-63010. I am looking for an aftermarket starter because the Kubota retail price for the starter starts at $550 and upwards toward $850. If anyone has gone down this road before and has found an aftermarket starter ~ please share with me. We own a ranch and this thing is used every single day and is sorely missed when it is down for maintenance. Kind Regards, ~ Stan
