Got done with my rewire and only made a few mistakes, got the 2wd and 4wd wires reversed. I ran the winch all the way out and back in and it seems my FET H bridge will handle the load, probably ought to try lifting it off the ground to make sure it can handle every thing rather than find out it can't in the field when needed the most.
Also need to replace the head light bulbs but I can't find one locally.
I thought I'd ask if any one has found a replacement, then start browsing the Internet.
Replacement Headlights I used are Sylvania H5006 High/Low. I would imaging the number is the same for any manufacturer. The Headlight sockets to change it over are Dorman 9003 High Temps.....
Thanks bigdan120, Put 2 Sylvania H5006 lights in today, but instead of buying the Dorman plug, I soldered some wires on and use some connectors I have on hand. Haven't had it out at night yet, maybe tonight.
Thanks, Kinarfi
  • 5 months later...
  • 4 months later...
hi all maybe this has been addressed idk. What are the connectors called coming off the main headlight with 4wires, 2hi/2lo+ground. I'm looking at a HID kit which has two 2wire connectors, like the fog lights have. is that a standard size, or number ?
You'll never drown, if you're born to hang
    • By JimG
    • By Kingfish
