2010 Redline Revolt...
The Motor and Turbo are freshly built with approx 30-40 hours
Turbo Smart Manual Boost Controller
New Primary Comet Clutch
Polished Intercooler w/ 6" Intercooler Fan
Polished Oil cooler w/ 6" oil cooler fan
Brand new Odyssey Battery
Fox Shocks
Aftermarket sway bar
5 point Harness
The larger 12" radiator fan
Window Nets
RPM gauge, Boost gauge, Oil Pressure gauge, Water temp gauge, Fuel gauge and Speedo gauge
Brand new Steering box
Heim joints upgraded
Custom Belt guard
Crankcase Overflow Can w/ filter
Gearbox Overflow can w/ filter
Custom 6" LED Baja Lights in front
Rigid 10” LED Lightbar
6” LED front bumper light
Skat-trak Extreme's in the Rear
Skat -trak 's in the Front
Custom front bumper
Redline Rear bumper
Has a Custom wrap
Donalson (dual) Filter system & additional Uni filter and Outerwear
Custom steering wheel
Wired for Dual Tribal whips
Extra's include:
(Brand New) Extra Redline F & R Gearbox/transmission
2 New Extra stock front rims
1 new Stock Rear Rim
Extra Primary clutch
Complete Clutch Weight set for tuning
Redline Clutch removal tool
Extra Steering box
4 New Carlisle Heavy duty Belts
3 Used Redline belts for back ups
1 new extra Radius rod
1 New extra Tie Rod
Multiple extra used Heim joints
1 New extra Shift Cable
1 New extra Throttle Cable
1 New extra Weber oil Filter
Extra used stock muffler
Stock steering wheel
1 extra used Fuel Injector rail
1 extra NEW complete (dual) Donalson Filter set
Complete factory manual
Complete Weber engine rebuild manual
$12,500
Just let me know if you are interested. 405-471-4828
    • By strike250
      Matt
    • By Jim Kessell
      Hi All
      Jim
    • By bms stallion owner
    • By SpaceGhost
