Moab Trip Report
By diamondjfarm
Thanks.
By Buck
My father-in-law has a Hisun 750. It has started to not change gears while running. He can turn it off, change gears, then restart and it will change. I thought it might have something to do with the brake but can’t find any info. Thanks in advance for any info.
By goindeep
Well now i could use a lil help... i have a trooper in my shop now that has wiring issues... this poor guy paid another shop $1000 to re wire the body control harness, and boy oh boy did they chop it up!!! I am Buillding a new harness from scratch... what i need is a diagram that tells me what each fuse and relay control on the Engine fuse/relay block.. any help is greatly appreciated!!
Josh
No Limitz
By NCPonyboy
Hello, new Hisun Axis 500 owner here. I have a 2020 in the Mountains of North Carolina. It runs fine and I enjoy it but it seems to struggle on the hills. Granted I have one that is pretty steep but you could get out and walk faster than it goes up. I sometimes wonder that if I had anything in the bed it might not make it. So first question is, is this normal for these? Second question is, is there anything I can do about it? Maybe a power adder or chip tuning?
Appreciate your thoughts
