Buying new Kaw mule 610 xc. Can't locate one in camo, was told by dealer the only difference between the standard Mule and the XC is the tire size,.Dealer suggested I buy a standard mule and swap tires for larger size, does anyone know if this is correct. Also, does the mule have any common defects I should be aware of? Thanks
kcoburn: Thanks for the info. I was able to get some more info, there appears to be several differences, suspension modification, wider stance, different steering wheel and the gear ratio. I plan to hold out hoping my dealer can find a XC in camo.
    • By Edelbrock
      Thoughts?
    • By Xov
    • By rsar
    • By TjB
