27" Sand Tires from GPS Offroad Products "High Roller".
By SouthernGypsy
By mac66
By Clint
New to the side x side experience. I bought a Coleman 550 Outfitter and I've seen conflicting comments about whether to use high or low range for running around under 15 mph. Comments?
By sxr951
