Has anyone purchased these tires from SuperATV? I'm talking specifically about the Dominators, 30x10-14's. They are (or were) really cool tires. We bought them in 2011, Lloyd wanted to go to 30" tires instead of the 28's that came on the trooper. We put 30x12-14's on the rear. Well, after less then half life, the 10 wides we put on the front have failed miserably. They have cracked right where the lug meets the carcass. 5 places on one tire and three on the other. The response we got from SuperATV was they would give us $50 off per tire for the purchase of new ones. After all, they are 2 years old. What does age have to do with wear? There's still plenty of tread left on the tires, they are not worn out. You can still see the wear bars on the tires. Lloyd and I feel it's a manufacturing problem. SuperATV refuses to do anything else, and so far we are refusing to buy any new tires from them. I would like to know if anyone else has had any better luck with these tires.
I'd bet that $50 is a customer satisfaction credit because the manufacturer who makes it for them is not going to give Super ATV any credit on those most likely. With age comes dry rot and cracking unfortunately. :(
I don't buy that the tires are dry rotted. Why would that only happen to the front tires for one, and for two - in EXACTLY the same place in a perfect line? Plus the buggy is parked under an awning out of the sun when it's not being driven.
I found out after digging, that the mfg discontinued these tires for a period of time not long after we purchased them. Hmm...wonder why that might be? Then they brought them back again late last year.
We did go ahead and purchase another set, so let's see how it goes. Still not happy with how they handled our original complaint, but we are kinda between a rock and a hard place as to where to get other tires the same size. So since they did discontinue and then bring them back, we shall see if they fixed the flaws they admitted to - and they did admit to flaws, although not the ones we found.
And just for the record, we were driving down a paved access road, about 1/10 of a mile long, no road hazards whatsoever last week - and a new hole blew in the right front. Sounded like a shot, and the tire was flat in an instant. It took 5 tire plugs to fill it. Our plan was to stay on a well used dirt track, nothing to put any stress on the tires, to just go to a spring and watch for wildlife coming in to drink. We didn't even get out of the driveway, basically. No, I don't buy that the tires are weather checked, when they are blowing holes continually where the lug meets the carcass. Lloyd said if he could hit road hazards in exactly the same location that many times over and over again, he needs to go buy lottery tickets.
The two front tires are toast, but the two rear ones will be held onto for spares.
Stay tuned.
  • 2 years later...
Update - got about 2 years out of the second set of tires - again the front ones started popping holes where the lug meets the carcass. Although, not nearly as bad as the first set. Still undecided what we will do next.
  • 11 months later...
    • By Duncan
    • By Ken rung
    • By rocmoc
      rocmoc in AZ/Mexico
    • By SouthernGypsy
    • By Nutcase
      I have a Joyner Trooper 1100 4 place that has been sitting for a number of years. I have everything taken care of but i can't get the fuel through the injectors. Fuel pump puts full pressure on them but they don't turn on or spray fuel. Any ideas?
