Don't like the wire. IF they don't get it on very tight and in the righe direction, the bolts can loosen if only a little. This is enough to allow the bolts to shear. Also it the bolts aren't metric grade 12.9, they are not strong enough. The loctited nuts on the back just adds another step of guarantee. With a new diff setting on the bench, you can correct the bolts in an hour or so. Not worth the risk and cost.
    • By Steve Waldner
    • By mcraigchr
      Howdy y'all,
      Craig C.
    • By Tejun
    • By SpaceGhost
