Was looking at a Kawasaki Mule 610 XC but now I am intrested in Polaris Ranger 500.
  • 3 years later...
    • By SouthernGypsy
    • By NC4wd
    • By se3388
      Steve.............
    • By Greg Kilgore
      Plumbing parts list.
      2 1" x 3/4" x 1" PEX Tee
      1 3/4" PEX ball valve
      1 1" PEX ball valve
      Wide view of the plumbing.
      Kilgore.
