When I'm riding and coming to a stop I push in the clutch my rpm stays up until I let out on the clutch a little then my rpm goes down and everything is ok is my throttle cable sticking ?
It seem to be the cable my trooper does the same thing i unplugged iac it still do that sometimes. When it sticks i would reach behind me and shut the throttle body by hand.. i have intake that is built by goindeep
Guest Lenny
Just any way that works. Mine is different so what I'm doing doesn't matter. Make sure that the spring doesn't pull over center so as to want to hold the throttle open when wide open.
Kinarfi that's an interesting idea i never seen that way before. Lenny that's good idea and i forgot yours was supercharged so different locations. You are right i would want to try have it pull from closed side to keep it from going over center
      Have an issue all the sudden where the UTV will cut out randomly mid range throttle and under load.  Light consistent throttle on fairly flat ground no problems.  If you quickly change throttle position sometimes it will bog down and cut out, splutter, etc.  Floor it or let off and it may do just fine.  Going up a hill and adding more throttle as the incline demands, will cut out splutter and smell unburnt fuel.  So far doesn't ever completely quit.  If you let off it will idle just fine.  A lot of times if you floor it, it will pick up and even get a boost of power.  Changed to a slightly hotter plug to see if that would make a difference, but it didn't .  Any ideas what might be going on and what to try next?
    • By TexAcoon
      I'm looking to purchase a 2015 Massimo 550 that might have an issue with it's throttle position sensor.
      I use my Hisun 550 (with the Coleman stickers), for general work around my 10 acres of hilly land. Hauling firewood, some dirt and mulch, and debris clean up. Also felling dead standing trees in the woods and hauling rounds out to the barn for splitting/stacking.
      Here's my question:  Those who use their UTVs with towed drag implements or snow plows, have you noticed any issues with early clutch slippage or failures?  Or premature belt wear?  Other drive line issues??
      Thanks in advance for any experienced thoughts and comments.
    • By Bjabbarw
    • By Howard Elmore
      I have owned mine for a couple years now but newer took off road.  How well does it do trail riding m?
