Throttle
By hdtran
By 4x4friend
I have a 2012 Hisun ut400 that I just bought. I was told it just needed a belt, but nope, all three clutches were shot. So I went online and found a couple videos on replacing the clutches. They stated that the wet clutch and primary clutch should turn easily counterclockwise and harder clockwise because it's turning the engine over. So that is what I'm getting when the wet clutch housing bolts are loose, when I tighten them the shaft now turns very hard counterclockwise. Anyone have any ideas as to the problem?
By Bryan83c
Need input on compatible clutch sets I can upgrade joyner 1100cc 2018 sand viper with. Something autozone might carry and what cars are these chery motors most compatibility with
By Chile
I have a 2018 Massimo 700 MSU with the Delphi MT05 ECU.
I have seen an alternative ECU reset procedure that involves running the engine at WOT for 5 seconds in neutral and then shutting down while throttle still at WOT. The articles include comments that the rev limiter will prevent engine overspeed ad attendant damage.
1. Is this actually a recommended procedure for restting the ECU on a 700 MSU?
2. What is the rev limited maximum RPM for the 700 MSU?
I initiated this procedure but when the RPM exceeded 6000 I immediately terminated the process. It simply seemed excessive to me to continue.
Any and all responses are greatly appreciated.
Chile
By DLJ
Have a Hisun 800 it runs for about 35 minutes then stalls. Crank's over but has no spark. Let it sit for 15 to 20 minutes and it starts and runs again for about 35 minutes. Changed the CDI / ECU controller and still does it.
