I was told these will fit the trooper I don't know but they look like what we use.
Dear Mr.David,
Regarding the spindle of trooper ,you can find them local .
I will give you the parts code and you can check it out.
1) Right front Knuckle= Arctic Cat 2003 ATV 500
Part # 0505-062
2) Left front Knuckle= Arctic Cat 2003 ATV 500
Part # 0505-063
7)RH REAR KNUCKLE ASSY= ARCTIC CAT: 2006 500 ATV
PART#0504-372-
Guest Lenny
I would bring a vernier caliper and measure to compare them with the stock ones.
    • By CYJSP2009
      Dear Joyner owners
      3. Cables,
      4. Brake parts
      5. Engine parts
      6. Other parts.
      Have a good weekend
      Casey /  Leaf Asia
      2023-11-17
    • By Gorj
    • By Bobbers
